Post by magoconnor on Jul 10, 2017 11:41:48 GMT -5
Hello. My bike was running okay, till I installed a 21mm phbg racing carburetor. Now it has trouple starting, and when it does you have to keep it alive with the throttle, but it can hold idle, after a few seconds. When I try to take off, it just sputters and then dies out . I have tried to adjust and try different kinds of settings, but nothing seems to work. It has a au atomizer which is used on two strokes, but i have talked with dellorto, they say it's fine. My main jet 90 Not sure about the neddle. Atomizer au 262 Choker 60 Idle unkown Please help me out! My Setup: Gy6 engine 50cc 72cc kit racing camshaft polini variator 6,9g naraku alu manifold intake spacer racing manifold aftermarket racing clutch, stock torque spring. OPEN AIR FILTER (rough grid foam) SlS system removed. All restrictions is removed removed the vacuum fuel delivery system.
Post by 90GTVert on Jul 10, 2017 14:49:23 GMT -5
Post by FrankenMech on Jul 10, 2017 18:39:49 GMT -5
Go back to the original carb setup.
Post by magoconnor on Jul 10, 2017 21:29:12 GMT -5
I swaped out the main jet for a size 80. Now the scooter runs much better, still needs to be fine tuned. Thanks for the help.
