Post by scouby3 on Jul 10, 2017 18:16:05 GMT -5
I have a standard 49cc. It wil not start with the switch. When I kick start it the headlight is bright and the blinkers will not blink. I replaced the starter. Any ideas? Thanks
Post by FrankenMech on Jul 10, 2017 18:38:28 GMT -5
Check the battery fuse first. If it is blown there is a reason. Go to the technical documents section here. Find yourself a schematic that matches your scoot as closely as possible and use it to follow the troubleshooting process in one of the manuals.
Post by lostforawhile on Jul 10, 2017 20:16:39 GMT -5
the battery circuit is not working for some reason, is the battery dead? is the key switch good? are there any fuses blown?
Post by V90Performance on Jul 13, 2017 13:44:25 GMT -5
Check the starter relay, test it by bridging the both terminals with a screwdriver. If it turns over, then its the starter relay. For the blinkers, replace the flasher.
