Post by leakycarb on Jul 21, 2017 3:02:20 GMT -5
I got new motor with carb and everything ran great for few hours then died now gas leaks from air filter and won't start help me please
Post by ryan_ott on Jul 21, 2017 5:26:19 GMT -5
I would suspect the float is either filled with fuel weighing it down causing to to overfill or the float swelled and got stuck down. Time to pull it off and check the position of the float. Could just be a piece of dirt stuck at the needle seat but you need to open it up and check.
Post by ThaiGyro on Jul 21, 2017 7:12:29 GMT -5
I would suspect the float is either filled with fuel weighing it down causing to to overfill or the float swelled and got stuck down. Time to pull it off and check the position of the float. Could just be a piece of dirt stuck at the needle seat but you need to open it up and check. Highly common problem here on new units with carbs...especially if stored in high temp areas. I have seen fuel inlet needles with damaged viton seats. Pain in the ass on a new scoot.
Post by pinkscoot on Jul 21, 2017 10:11:16 GMT -5
I've learned to clean a new carb to get all of the dust and dirt left over from manufacturing.
Post by leakycarb on Jul 23, 2017 11:03:14 GMT -5
Thanks that worked
