Post by stancejontland on Jul 21, 2017 11:42:01 GMT -5
Back again guys. A while back I had put my plastic engine shroud on and ever since the plug wire keeps popping off while I'm riding. It never ever did that b4. I know your gunna say do you have it on right or in the whole way and yes. I do. But for some reason it pulls the plug off.
Post by jeff84 on Jul 21, 2017 12:51:46 GMT -5
replace the spark plug boot, they are pretty cheap. even salvage it from some other motor.
Post by geoffh on Jul 21, 2017 15:57:44 GMT -5
Also check that your engine shroud is fitted properly and doesn,t wobble around,and while your there check that your plug cap fits the plug snug,I,ve seen 2 types of cap 1 fits on the bare plug thread and one fits over the alloy nut that covers the thread on a new plug.On a good cap you can see a wire/spring that will grip the plug check that's still in there.
Post by ryan_ott on Jul 21, 2017 21:28:29 GMT -5
Switch your boot to the normal snap on type instead of the threaded type and you have better success. NHL caps are available at your local auto store cheap.
Post by stancejontland on Jul 21, 2017 21:52:27 GMT -5
Mine doesn't thread
Post by jeff84 on Jul 21, 2017 22:35:59 GMT -5
Switch your boot to the normal snap on type instead of the threaded type and you have better success. NHL caps are available at your local auto store cheap. in my experience the opposite is true, the adapter always comes unscrewed from the plug I have found
Post by stancejontland on Jul 22, 2017 0:58:31 GMT -5
Can I just squeeze the thing that goes on the plug
