larryhobman
Post by larryhobman on Jul 31, 2017 22:38:35 GMT -5
Just a word about gears, I have been looking into them a lot lately. You can have 2 different stock sizes which changes your final gear set when you upgrade.
Stock primary set 53/15 and secondary 52/14 will give a final of 13.124
stock primary 52/16 and secondary 51/15 gives a final of 11.05
primary 53/15 and secondary 49/17 is a final 10.184
Primary 52/16 and secondary of 49/17 is a final 9.37
So check your Primary gears before you order secondary gears, I have all 4 combinations.
With the common 49/17 secondary gears and the 52/16 secondary which is very common your final is 9.37 which is too low for the 47mm kit as I had it set up. The best I had was 46mph. If you use the 53/15 primary and 49/17 secondary you get 10.184 final I might try that combo next but I switched to 11.05 right now.
I see a bunch of chat on gears so I just wanted to put it out there.
