Post by denton424 on Aug 11, 2017 21:00:05 GMT -5
Scooter bros, I need some help! So i picked up a long case minarelli for my build thinking it would go in fairly easy and now i am at a halt as far as mounting it. Here is what came out of my scoot. I has this H type bar that mounts to the engine then that mounts to the frame. Setting the engine back a little bit. The long case has a rod that is mounted to the motor that the bolt goes through. what is the best approach as far as mounting this long case in its place? Mind you the thru bolts are different diameters on the engines. Has anyone encountered this before? Can i just bolt the motor straight to the scooter frame and skip the H bar or can i get different bushings for the long case and use the H bar how it is intended? if that is the case where can i find these bushings?
Post by jeff84 on Aug 11, 2017 22:25:46 GMT -5
if it will fit without the extender then you don't need it. but I bet not only do you need it, you need to make it longer to clear the frame.
Post by denton424 on Aug 11, 2017 22:56:03 GMT -5
I don't think I will need to make it longer I just need to figure out how to get these bushings out and switch them to the new motor I think. I tried putting the motor up in with out the bar and I don't think I will have room for a carb haha.
Post by jeff84 on Aug 12, 2017 1:54:42 GMT -5
good luck getting those bushings out in one piece. heat the metal but not hot enough to soften the rubber, then using a socket the same o.d. of the bushing try driving it out with a hammer. I would take some measurements and shop around online for bushings by size
Post by 190mech on Aug 12, 2017 3:50:54 GMT -5
Post by denton424 on Aug 12, 2017 6:11:51 GMT -5
How do I know that they will be the correct inside diameter for the bolt.
Post by oldgeek on Aug 12, 2017 7:17:18 GMT -5
The ones 190mech linked for you are the correct ones. Not to discourage you, but that mount is a PITA to work with. Take your time and get the intake sealed up correctly, you dont want to have to pull it all apart again, again.
Post by denton424 on Aug 12, 2017 20:04:43 GMT -5
I think I figured it out! I'm going to play around with it tomorrow. Will update in this thread and the build thread.
Post by ThomasTPFL on Aug 13, 2017 8:38:10 GMT -5
Pay attention to where your wheel is lining up. I swapped from a short case to a long case, 90/90-10 to 130/70-14, and the new rig had to sit a good bit to the left of the previous engine. All.my engine mounting stuff has been hacked and welded.
Post by denton424 on Aug 13, 2017 8:47:32 GMT -5
Pay attention to where your wheel is lining up. I swapped from a short case to a long case, 90/90-10 to 130/70-14, and the new rig had to sit a good bit to the left of the previous engine. All.my engine mounting stuff has been hacked and welded. I just have the 10" wheel mounted up for right now. But I will look at it when I go to bolt it up
