Post by matthewwhitaker on Sept 7, 2017 23:12:30 GMT -5
Hello I've just seen 49 sccot vid on YouTube and would like to try an make a 90cc 1e40qmb but don't now where to get the parts I'm in the UK can someone help thanks Matty
Post by 90GTVert on Sept 8, 2017 8:22:51 GMT -5
I'm not really sure about UK specific sites.
autotech355 on eBay sells some cylinder kits and cranks and he's in Taiwan so he prob ships worldwide.
partsforscooters.com has some cranks and cylinders.
I have seen 42, 45, and 48mm stroke cranks on eBay. Not sure of the sellers, just searching.
g-forcepowersports.com has a lot of high end stuff (2FAST, Malossi... $$$$). I'd imagine you can find the high end stuff in your country pretty easily.
kaseaparts.com carries the small parts and odds and ends (fan shrouds, nuts, studs, etc...) and they also have performance parts.
I found out the hard way not to buy the cheapo cylinders on eBay. I had 3 of them. One came cracked. The ones I ran were noisy from poor clearances. It's worth the money to get a decent Taiwan made cylinder.
Post by moofus02 on Sept 8, 2017 9:18:15 GMT -5
Auto tech 355 used to sell a kit for converting 50cc cases. Didn't have to cut the cases as much for the crank. I think that kit was 54 bore x 42 stroke. You could also use a crank Athena makes for their 80cc kit. 43 stroke 12mm piston pin but it fits in 50 cases without cutting. That and a short 54 cylinder would make a nice kit. You could also try their entire 80 kit. 47.6 bore x 43 stroke requires no case cutting but I would back fill and trench. They claim 17? Hp with a c16 pipe. Not quite as torque as the big motors but should make a fine street motor that doesn't have to turn to the moon for power
Post by geoffh on Sept 8, 2017 15:47:09 GMT -5
Matt,Euroscooter parts are a UK supplier who list all the big names airseal,malossi etc I,ve bought bits and bobs off them for years,never had to phone or chase any orders just click pay and it arrives.
Geoff UK scoot user
Post by joggybro on Sept 11, 2017 11:41:07 GMT -5
You could either spend the money buying crankcases etc.. In ebay u can find eton and polaris 90cc crankcases they look very similar maybe some of the american guys here can chime in whether they are different or not,im currently looking for a cheapish 90cc crankcase simply to install a polini big evo cylinder and crank, Maybe someone here knows whether the 90cc crankcases still need to be machined to fit the big evo kit. Im in uk and this is wat im looking to do aswell
Post by moofus02 on Sept 11, 2017 18:13:31 GMT -5
Short or long case? The 90 cases will take the high end big stuff with no cutting but you should still trench and match them
Post by joggybro on Sept 13, 2017 19:11:02 GMT -5
Moofus u reckon the best way is the judt grt a cheap aerox 100 case so involves less work?i.e for the hyper race stuff?
Post by niz76 on Sept 13, 2017 22:08:01 GMT -5
Hellz ya if u can get an Aerox 100 case get it! Those Aerox parts aren't available to us here in the US so we don't typically think of that but wish we could get them here. Just keep in mind it will use different parts than a 1e40qmb...
Post by joggybro on Sept 14, 2017 10:32:10 GMT -5
Will the polini big evo cylinder and crank fit without milling the case?
Post by Deleted on Sept 14, 2017 12:00:31 GMT -5
If ur in the UK, you should be riding a 180cc scooter. I like these over the dragster.
Post by 90GTVert on Sept 14, 2017 17:36:53 GMT -5
Don't get an Aerox 100 if you want a high end build. AFAIK, you can only get street/sport cylinders for them.
The Big Evo will need case cutting to work on 49cc cases.
Post by moofus02 on Sept 14, 2017 18:45:46 GMT -5
Bent is right the 100cc Yamaha cases won't work with the normal 50 or 90 parts. Bearings, cranks and cylinder stud spacing are all different. Stick with the 50 or 90 cases
Post by joggybro on Sept 14, 2017 19:53:12 GMT -5
Yeaaa i get ya i didnt give it a thought about the cylinder studs and spacing lol i got too ahead of myself just thinking about the milling and fitting of crankcase lol
Post by joggybro on Sept 14, 2017 23:33:35 GMT -5
Is the e-ton atv 90cc case the one i should get?
Post by 90GTVert on Sept 15, 2017 4:50:58 GMT -5
Probably. You can look at pics and tell. If it's a Minarelli and it doesn't have a reverse gearbox, then that should be what you're after. The reverse geabox is huge and easy to spot. If you want to use the gears from an ATV engine, then you have to make sure it has a regular axle and not a shaft meant only for a sprocket to mount to.
