Post by bendover on Sept 14, 2017 14:35:53 GMT -5
Attached is a dyno chart of piaggio AC engine with 70cc polini sport. Stock exhaust in chart is restricted*.
Oftentimes an "aftermarket exhaust" is considered mandatory for tuning, or at least first upgrade. Sometimes even full expansion chamber exhausts. I say stock derestricted exhaust will fit very many, if not most, much better than aftermarket exhausts.
If one would want a stealhy but nice off-the-line accelerating scooter, you would not change your exhaust from stock. Right?
Why?
Even in restricted form, it would be the best choice above all other tested exhausts. Derestricted it would outperform other exhaust even more. Even if you change rollers and clutch springs, you would have to tune variator to be at > 6800 rpm (!) to be able to get more power than the stock exhaust even in restricted form. Derestricted you get 5+ hp at 5500 rpm with stock derestricted, while you need 6800+ rpm for same power with leovince zx. As an added bonus, you can keep your stock variator, stock rollers and stock clutch.
Bottom line:
Below ~6500 rpm you will ALWAYS have more power with stock exhaust - and substantially so if it is derestricted. In other words - to gain power from aftermarket exhaust, you MUST tune variator to > 6500 rpm, and SHOULD tune it to > 8000 rpm depending on exhaust. If you don't, you LOSE power, in addition to reliability, stealth and money. In addition you SHOULD tune clutch to engage a lot later than stock, if you don't, upgrading will make you lose off-the-line acceleration and you will be behind for many seconds, ie. very many meters/yards before catching up. This is a classic problem - "I bought all this stuff, now I take off like a slug.", and after tuning variator and clutch, "Now I take off ok, but rpm and noise is insane!".
This is why derestricted exhaust will fit very many, if not most, much better than aftermarket exhausts.
Yes?
* - "Original exhaust" is the stock RESTRICTED according to the source, pedoparts.
Why?
Bottom line:
Yes?
