Post by jdl357 on Sept 15, 2017 20:28:17 GMT -5
I bought a new CVT cover and am having trouble removing the bearing in the CVT cover that the end of the rear clutch pulley goes in. Any advice for getting this out?
Post by spaz12 on Sept 15, 2017 23:43:43 GMT -5
Try packing it full of grease and shoving something into the bearing that's the same size as the part of the shaft that normally goes into it. It's sorta like a hydraulic ram.
Post by ryan_ott on Sept 16, 2017 19:30:50 GMT -5
I've read of people using bread for the same purpose. Would probably work better for open bearings where you would loose the grease between the balls.
Post by 90GTVert on Sept 18, 2017 6:35:03 GMT -5
They need to be replaced in mine too often (I buy 'em in 10 packs on eBay), so I just drill a hole slightly larger than the center of the bearing in the cover. Then I use a punch to knock it out. Heating the cover makes it easier. I heat the cover when the bearing is ready to go back in and use freeze spray (duster held upside-down) on the bearing (or put the bearing in the freezer for a couple of hours at least).
