Post by spaz12 on Sept 20, 2017 2:21:54 GMT -5
Pretty much the only spring I use is a yellow Malossi. If I have a torque drive that is old and won't shift right even after servicing, then I will use the really soft pink Stage6. Switching to the yellow spring will more than likely cause you to have to use different roller weights, but like I mentioned earlier that the zx-r likes the lighter weights and so if you use 4.3 gram rollers, yellow contra and yellow clutch springs then it should work.
You ever figure out what cylinder is on there? Is it aluminum, or cast iron?
Post by benji on Sept 20, 2017 9:33:13 GMT -5
Also jets and what brand phbg would help. If it's a clone carb it may be tough to get tuned right. If you haven't changed jets then you need to. Put on a stock airbox, it'll help quite a bit.
Post by pinkscoot on Sept 20, 2017 10:51:12 GMT -5
kdx
Post by kdx on Sept 26, 2017 21:54:52 GMT -5
Pretty much the only spring I use is a yellow Malossi. If I have a torque drive that is old and won't shift right even after servicing, then I will use the really soft pink Stage6. Switching to the yellow spring will more than likely cause you to have to use different roller weights, but like I mentioned earlier that the zx-r likes the lighter weights and so if you use 4.3 gram rollers, yellow contra and yellow clutch springs then it should work. You ever figure out what cylinder is on there? Is it aluminum, or cast iron? Uhhhh the cylinder is black that’s all I know I will look at it when I get home tommorow
kdx
Post by kdx on Sept 26, 2017 21:55:51 GMT -5
Also jets and what brand phbg would help. If it's a clone carb it may be tough to get tuned right. If you haven't changed jets then you need to. Put on a stock airbox, it'll help quite a bit. delloroto phbg 19 racing. Went all the way up to 110 on mj don’t have stock airbox unfortunately
Post by ThaiGyro on Sept 26, 2017 23:58:21 GMT -5
I am running a PHBG 19mm on a tuned 49cc, but a very different pipe and variator. My current setup is a 92 main, (airbox) a #50 pilot and a W6 needle. My pipe has most power in mid-range...peaks about 10,200 rpm. My variator tuning won't compare, until I install the new CVT. The OEM Gyro's are 2 speed setups, nearly like a regular CVT, but not.
