Post by outboardman on Sept 19, 2017 16:44:39 GMT -5
I don't know what you guys think of sprees, but I picked up a 1987 for pretty cheap. The problem is the electric start doesn't work, so I have to kick start it, and it is hard to start, most of the time, but sometimes it will start in 2 or 3 kicks, but usually it takes 10 to 20. the compression is only 100 psi, can this be the problem? When it starts it runs nice, yes I cleaned the carb real good, new plug, good spark. this is not my first spree, the others all started good.
Post by eclark5483 on Sept 19, 2017 17:43:50 GMT -5
Are you using the stock airbox with a clean filter?
Post by gsx600racer on Sept 19, 2017 18:09:27 GMT -5
Have you checked the auto-bystarter(auto choke) to see if its working properly?
Post by outboardman on Oct 1, 2017 21:23:12 GMT -5
ok, I replaced the bystarter, cleaned the carb. twice, now sometimes it will start and run good, then the next time I try it it won't start, or will take many kicks to start it. I even checked the reed plate, it is ok. I think maybe the carb.is bad, but the are pricey. any thought?
Post by jeff84 on Oct 1, 2017 21:43:41 GMT -5
worn rings, crankcase leak?
