Post by drbob on Sept 25, 2017 18:39:20 GMT -5
Kinda figured out the random issue with me getting stranded on the side of the road randomly and not getting fuel at all.when it happens if i tap the bottom bowl of the carb with a wrench it solves the issue. Has done it to me 8 or 9 times in the last few months so im just going to replace the carb. Looking for suggestions on cheap decent replacement. 1e40qmb vento zip clone. Stock except tecnigas next r pipe.
Post by geoffh on Sept 26, 2017 15:11:50 GMT -5
Drbob I purchased a clone dellorto from ebay $20 ish,it,s been fine worked straight out of the box,it was already set to suit a stock set up but be ready to alter as required,I,m UK based but I,m sure you have them in the land of the free.
geoff search e bay (minarelli 50cc carb)160600882460 321814671637 both would get the job done
Post by pinkscoot on Sept 26, 2017 16:43:37 GMT -5
I've used a few of these with no issue. You can get jets, needles slides and other parts from Treatland. They have the manual enricher that can be cable run or you can get a pull knob, all from Traetland.
Post by drbob on Sept 28, 2017 8:59:03 GMT -5
not sure if this one i got is set up for the oil pump system so i may have to switch to premix. If so is there a way to disconnect the auto pump system withouy having to remove the flywheel and etc., video ive seen shows removing all that to take off pump system
Post by catchacuda on Sept 28, 2017 10:30:01 GMT -5
The one you show has the brass barb for the oil injection hose. Ive deleted it by removing the pump (2 phillips screws) and made a simple block off plate. Removing the flywheel and whatnot is to access and remove the plastic oil pump drive gear, and the pump can stay in place.
Post by geoffh on Sept 28, 2017 15:01:53 GMT -5
+1 with catchacuda,your oil feed pipe will fit on the brass fitting shown so no need to go premix unless your worried about it failing.
geoff
