Post by honda4life on Sept 27, 2017 16:01:55 GMT -5
It came with a 50 pilot jet and I was told to go with a 40 or so. I ordered a 38 and put it in today. It runs pretty good-with the a/f screw turned out 4-5 turns. I'm guessing I need a larger pilot now? What do you think? Like a 42? 45? Acceleration is pretty seamless without any flat spots but when I FIRST start (with 2 turns out) it was bogging really bad and would cut out. When I backed it out to 4-5 it accelerates really good.
Post by pinkscoot on Sept 27, 2017 18:18:30 GMT -5
4-5 turns out is pushing that pilot jet so I would so yes you need a larger pilot. The 40 would probably be better. Which needle and slide are you using?
Post by honda4life on Sept 27, 2017 19:54:55 GMT -5
I am using W7 needle 1 notch from top, 85 main, 38 pilot, If I am at 4-5 turns out on a/f screw I'm thinking like a 42 pilot? I'll order a 42&45 because I will probably be going bbk next spring anyway. Sound good? Treat here I come!!!
Post by tsimi on Sept 27, 2017 20:04:37 GMT -5
Try to put the needle to second from top that should richen it a bit. If you do that you might have to adjust the main jet again and mixture screw. Try mixture screw to 1.5 turns out and see how that goes.
Post by honda4life on Sept 28, 2017 8:02:05 GMT -5
Thanks guys. I love tinkering with things but there's too many variables in a carburetor!!!! It gets a little confusing at times. Maybe that's why I love scooters so much. Haha
