Post by triumphmad on Oct 1, 2017 1:53:06 GMT -5
Anyone know what size the stock variator rollers are for a Peugeot Blaster. Also can I use slightly larger rollers to get max top speed. My last set of rollers got very bad flat spots on them after about 1000km, is this normal? Thanks for any help.🛵
Rune 75
Post by Rune 75 on Oct 1, 2017 4:22:13 GMT -5
Can't use larger rollers.
Post by pinkscoot on Oct 1, 2017 10:24:33 GMT -5
Measure the old ones and replace with that size roller. Don't go larger because it will cause all sorts of heart ache.
Post by aeroxbud on Oct 1, 2017 18:42:09 GMT -5
A good brand of rollers should last way more than that. If you have been revving the scooter a lot at a standstill, the rollers won't last long.
Post by triumphmad on Oct 2, 2017 3:15:59 GMT -5
They were molossi rollers. I do push it hard but don’t rev it on the spot. Should I be using any lube on the variator, something like CRC or WD40 or is it best left dry.?
Rune 75
Post by Rune 75 on Oct 2, 2017 5:06:15 GMT -5
They were molossi rollers. I do push it hard but don’t rev it on the spot. Should I be using any lube on the variator, something like CRC or WD40 or is it best left dry.? It's best left dry. You can clean it with WD-40 but wipe it off thoroughly with a clout or paper.
