Post by chicoscoot530 on Oct 5, 2017 11:52:59 GMT -5
So Richard recently purchased a 90 mL cylinder head piston gaskets rings etc. for my motor. Do I have to change the crankshaft to a stroker crank with the 90Cc cylinder? Thank you
Post by moofus02 on Oct 5, 2017 12:24:56 GMT -5
If you are starting with the regular 50cc motor you will need to cut the cases for the crank and cylinder. The 90 motors run 50,52 or 54mm cylinders in 2 different heights and 42 to 45mm cranks
Post by chicoscoot530 on Oct 7, 2017 22:30:19 GMT -5
The motor intended for this is a Kymco kfa6, it started as a 50 but has malossi 70 cc bbk now. When you say cut the cases do you mean that I have to or the left and right case to except the cylinder sleeve and cut to create space for the crank thanks for your reply
Post by moofus02 on Oct 8, 2017 1:21:05 GMT -5
The motor intended for this is a Kymco kfa6, it started as a 50 but has malossi 70 cc bbk now. When you say cut the cases do you mean that I have to or the left and right case to except the cylinder sleeve and cut to create space for the crank thanks for your reply That's what I meant. I was thinking the Yamaha/minna cases. I don't know on those. Maybe the Honda guys can chime in on this
