Post by RollingThunder on Oct 6, 2017 16:29:47 GMT -5
I unsealed my carb this week so I could tweak my air/fuel screw and found that my Keihin carb uses a d slot head. Does anyone know what size it is and where the best place is to source one from? I had a few different sizes at my old work so I know they aren't all the same size. I had a super handy one that was short and had a knurled knob on the end to adjust some ATV carbs but it wasn't very cheap.
Post by FrankenMech on Oct 7, 2017 1:32:54 GMT -5
Somebody else here had that situation. I don't remember who and what the solution was. I would just slot it with a Dremel tool cutoff wheel.
Rune 75
Post by Rune 75 on Oct 7, 2017 5:04:21 GMT -5
If you have an old telescopic radio antenna it's easy to make the D-shaped tool you need. Cut out the part of the antenna that have just the right diameter to fit tightly around your D-shaped a/f screw, and then give your antenna a dent to make it D-shaped. Done it myself, works great.
Post by RollingThunder on Oct 7, 2017 9:32:06 GMT -5
Thanks guys. The antenna idea is great! Unfortunately I don't have an antenna laying around, but I might have something else that will work. I found the tool I used to have for $16, which isn't bad. On the other hand, I can order a rebuild kit for $8.50 and not have to worry about having a special tool to adjust the fuel screw and then I'll have an adjustable jet needle. That's the route I'm going!
rdemilt
Post by rdemilt on Oct 7, 2017 14:04:26 GMT -5
Ive read that you can also heat the end of an Bic stik ink pen, push it on the screw and remove it. I choose the dremel tool, Just cut a small slot and adjust away.
