Post by jireland1221 on Oct 23, 2017 6:32:05 GMT -5
installed a 72cc bigbore kit. Started it by hand choking/ covering the air intake on the carb. It started, ran for about three seconds, and died. Had low power. Now, it won't start. Where should I start?
Post by catchacuda on Oct 23, 2017 7:30:14 GMT -5
Post by jireland1221 on Oct 23, 2017 8:35:43 GMT -5
No it did not. Low compression and siezed second ring meant I needed to replace the piston.
Post by pinkscoot on Oct 23, 2017 16:36:18 GMT -5
What scoot? Did you up jet the carb? Is the air box and exhaust installed? What carb?
Post by jireland1221 on Oct 23, 2017 18:02:27 GMT -5
What scoot? Did you up jet the carb? Is the air box and exhaust installed? What carb? I did not mess with the jet. Has a new carb. Air box is not installed. Exhaust is. On a 2011 Tao Tao ATM 50 A3.
Post by lostforawhile on Oct 23, 2017 18:08:29 GMT -5
if the airbox isn't attached it wont start
Post by acvw74 on Oct 23, 2017 18:18:51 GMT -5
Start with the basics: Air Fuel Fire (Spark)
Post by lostforawhile on Oct 23, 2017 18:20:07 GMT -5
these carbs are really ticky about the airbox not being connected
