Post by jtgearhart on Oct 29, 2017 11:41:26 GMT -5
ok i big bored my scooter and for some reason it wont start on the electric start but kick start will work or would til i broke the side case where the kick starter was,now if i jump start of a bigger battery sometimes itll start as well, i went over all my wires and fixed ends and whatnot but im just running out of ideas, i have fuel spark compression timing is correct just cant quite figure it out...
Post by jtgearhart on Oct 29, 2017 11:51:49 GMT -5
also i bought a new battery and with jump starting it still barley does it...
Post by kagetenshi on Oct 29, 2017 13:15:57 GMT -5
I'm almost willing to bet your compression is too high seeing as it will kick-start but won't with the electric starter. Could be your battery is a bit weak. Could be a weak starter.
Post by cagiva4ever on Oct 30, 2017 7:34:26 GMT -5
already lotsa answers to these guestions on this forum, for every single1. including UpGrades to fix/make less worse such issues.
have a read search.
what has happened to you so far is 1:1 Classic case.
Post by 90GTVert on Oct 30, 2017 15:22:11 GMT -5
It is a common thing when compression gets high on BBK builds. I have replaced the starter cables and grounds with larger cables and had some improvement before. I used 8AWG car audio power cables, like you'd use to install an amp. Replaced the cable from batt to relay and relay to starter. Then replaced batt to frame and engine to frame grounds and made the grounds meet at the same point. If your compression is too high for starting, it may be high enough to cause spark knock and overheating too so it's not a terrible idea to do a compression test if you can.
