Post by badluna on Oct 30, 2017 21:15:30 GMT -5
So I wanted a straight pipe because I want people to hear me when I'm coming through. But now my scooter won't start. Does it need back pressure that badly? Sigh.. I tried putting a richer idle nozzle to no effect.
Do I need to buy a replacement now?
Post by lostforawhile on Oct 30, 2017 21:21:23 GMT -5
I have a cherry bomb, I think the pipe itself is enough back pressure, on a 2T of course the pipe is critical as everything is tuned to scavenge the cylinder, others have run open pipes with no issues.
Post by badluna on Oct 30, 2017 22:34:11 GMT -5
I have a cherry bomb, I think the pipe itself is enough back pressure, on a 2T of course the pipe is critical as everything is tuned to scavenge the cylinder, others have run open pipes with no issues. So why do I have this issue. Could it be I'm blowing out my cdi? That fixed the start issue last time. Guess I'm going to start buying ignition parts again.
Post by badluna on Oct 30, 2017 22:45:19 GMT -5
I should add. Maybe the issue lkes some where else. Lately I've been blowing fuses. I thought indie to my malfunctioning horn but maybe not
Post by badluna on Oct 31, 2017 19:09:17 GMT -5
Took the stator off. Saw a lot of dirt. Stator looks fine. I tried another cdi and ignitor no good. I'm completely lost.
Post by lostforawhile on Oct 31, 2017 19:15:05 GMT -5
have you checked actual running voltage
Post by badluna on Oct 31, 2017 20:21:52 GMT -5
56v on charging when using the a.c. setting on my. Multimeter. Where should it be?
Post by humanshield on Oct 31, 2017 20:46:40 GMT -5
It should run with a straight pipe.
It will even start with no exhaust at all.
Look somewhere else.
Post by lostforawhile on Oct 31, 2017 22:09:22 GMT -5
56v on charging when using the a.c. setting on my. Multimeter. Where should it be? while running or cranking? there are different opinions on a good cranking voltage but the general consensus is around 50 or above while cranking
Post by lostforawhile on Oct 31, 2017 22:10:45 GMT -5
did you ever check your valve clearance?
Post by badluna on Oct 31, 2017 23:11:20 GMT -5
did you ever check your valve clearance? Yes with my feeler guage I have modified: air intake (I have put back stock until I get this running) Bbk 50mm Exhaust. Its now a straight pipe. I have replaced: (within 48 hrs) Carb Ignitor Spark plug Cdi Oil (Plus the thing next to The stator that tells the vid when to fire with the blue cable) I have tested: Compression test. 120psi @ WOT Valve clearance Ignition coil on stator fuel flow is excellent Last time I got it started it was systematic of a engine running lean with out black smoke. Needed lots of throttle for even low rpm.
Post by lostforawhile on Nov 1, 2017 9:35:37 GMT -5
Check your clearance on the pickup,the thing next to the flywheel, also check it's output DC should be around .6 volts I think, the clearance is often way off. And it's too far from the flywheel. I had to take my new one and drill the holes bigger to move it closer to the magnet (outside of flywheel there is only one) a weak igni th ion signal can cause this
Post by lostforawhile on Nov 1, 2017 9:36:21 GMT -5
Post by lostforawhile on Nov 1, 2017 9:36:35 GMT -5
Post by badluna on Nov 1, 2017 15:28:04 GMT -5
Im going to try that but I'm not confident. Any thing else i should try. I literally don't know what else to do
