Post by substars7 on Nov 1, 2017 11:44:41 GMT -5
I recently just purchased a TaoTao 50cc scooter and when I ride it, it tends to stall when I come to a light or stop sign unless I constantly rev the throttle. any suggestions on how to fix it? (I don't know much about scooters) Thanks
Post by 90GTVert on Nov 1, 2017 15:49:45 GMT -5
Post by bullcharles1 on Nov 2, 2017 10:03:11 GMT -5
Needs either more air or more fuel. With a stock carb your only choice is more air, after warming up screw in the idle screw until it's idling at a desired speed
Post by jackrides on Nov 2, 2017 23:04:17 GMT -5
How many miles? Maint. history?
Post by substars7 on Nov 3, 2017 8:54:43 GMT -5
How many miles? Maint. history? Its new, I've only had it about a week now but its been happening since I got it.
Post by benji on Nov 3, 2017 9:11:11 GMT -5
Have you changed the oil? The tao taos come pretty bare bones and many people on here have stated that you MUST go through and do a 'final inspection's and swap fluids/tighten bolts.
Post by greginisn on Nov 3, 2017 23:11:37 GMT -5
Lots of good suggestions here but one other thing is to check the valve adjustment. Tight valves can cause stalling at idle type problems too. A little loose is better than a little tight.
Good luck, Greg
Post by pinkscoot on Nov 4, 2017 10:07:15 GMT -5
I agree with Greginism, if you didn't check the valves when you got it that is a good place to start.
