Post by uhmdave on Nov 10, 2017 19:39:32 GMT -5
I drive Peugeot sf1 and I have tecnigas Next R installed on it. Since I bought it, exhaust had some weird sound(tecnigas next r was installed when I bought it). If someone knows the solution please answer this one! How to fix this? vimeo.com/241906404 here's the video of the sound.
Post by gsx600racer on Nov 10, 2017 23:21:20 GMT -5
Sounds like music to me.
Post by benji on Nov 11, 2017 10:35:33 GMT -5
I would pull the plug and check it, may be running lean and pinging.
Post by edwardtennant on Nov 11, 2017 15:41:41 GMT -5
Sounds awesome, but benji could be right. If the plug is white on the end it is lean and you need a larger jet. if it is black it is rich and need a smaller jet and also make sure your choke is working properly. it should be the colour of a cup of tea
Post by triumphmad on Nov 13, 2017 3:59:43 GMT -5
When I got my technigas next R it had a restriction washer in it where it bolts to the engine. Can’t remember if it changed the sound but it would pay to make sure it has the washer removed. Only took a few minutes to remove it & it went loads better afterwards.
