Post by badluna on Nov 20, 2017 12:10:17 GMT -5
So I got the dc cdi. I half converted my scooter.
I out back the stock airbox but I still have thebstraight pipe.
Before I ran a 42 pilot with a 78 main
I havent got my tune right get but it looks like I'm going to be doing 38 with a 85+ is that normal?
Also she only starts with a drill. I'm not sure why it won't start with the starter
Post by GrumpyUnk on Nov 22, 2017 13:17:22 GMT -5
Likely the 'slow' carb circuit needs adjustment or has something plugging the idle mix passages. You can try making the idle mix richer or leaner. Does it idle after you get it started, or do you have to keep the revs up? If you need revs, then for sure check the carb idle circuits. tom
