Post by rzsmith on Nov 22, 2017 17:54:04 GMT -5
Post by gsx600racer on Nov 22, 2017 17:57:41 GMT -5
Did you remove the variator when you changed the belt ?
If "NO", chances are the rollers in the variator are not positioned properly.
Post by rzsmith on Nov 22, 2017 18:07:14 GMT -5
I did not remove it, could it still be the rollers? Would that cause me to lose that much on a flat? 30mph difference seems steep over just rollers! As I said I have no idea how these engines operate. I can swab a b16 in a moments notice so I assume these should not be that complex.
Post by rzsmith on Nov 22, 2017 18:08:21 GMT -5
Double tap the post. How SHOULD they be positioned?
Post by uglo on Nov 23, 2017 1:32:06 GMT -5
Has to be the wrong size belt.. or you've got some serious roller issues. Or your clutch is slipping like mad. Excessive amount of dust in cvt after changing belt?
Post by 90GTVert on Nov 23, 2017 6:26:36 GMT -5
When the belt breaks, the rollers can get out of place because nothing is there to keep the variator pushed back. You can also get debris in various parts. If I break a belt, I clean the entire CVT.
Post by rzsmith on Nov 27, 2017 23:16:15 GMT -5
So i finally got around to ripping this scooter apart, Cleaned the clutch the variatior, Noticed the rubber clips that support the rollers were missing. Replaced and i am now happily cursing at 35mph. still 10 MPH lower, but i am gonna tweak and tune to get everything adjusted!
