puta
Post by puta on Nov 23, 2017 2:07:01 GMT -5
Hello guys... what should i do with my yamaha Beluga.... my problem is inside the gear box that i feel something vibrating when i going to start accelerate... and when my Engine is going to move.. my rear wheel is getting rough or also vibrating... and my oil is leaking inside the crank... what do you think guys is the problem of my scoot... Thanks a lot!!!
Post by collinsd84 on Nov 23, 2017 15:40:22 GMT -5
2-stroke or 4-stroke?
puta
Post by puta on Nov 23, 2017 23:46:09 GMT -5
MY Scooter is YAMAHA BELUGA/RIVA/CA50 1982 AND 50CC 2 STROKE ENGINE
Post by 90GTVert on Nov 24, 2017 8:35:53 GMT -5
Have you taken anything apart to inspect it yet? That's my first thought. Maybe you'll see what is wrong. Gear oil may be full of "glitter". Maybe bearings will feel or sound rough.
puta
Post by puta on Nov 24, 2017 10:17:55 GMT -5
I didn't inspect it and check out what is wrong inside my gear box.. but tommorow i'm going to try to open the gear box then i'll show it to you... thanks for advice admin☺
Post by pinkscoot on Nov 24, 2017 11:45:50 GMT -5
Is this the scoot with the oval wheel? It helps if you continue on the same thread and tell us when you find a problem.
puta
Post by puta on Nov 24, 2017 18:55:53 GMT -5
What do you mean pinkscoot?☺
Post by pinkscoot on Nov 24, 2017 20:09:43 GMT -5
Post by lostforawhile on Nov 24, 2017 21:22:25 GMT -5
the fact that the wheel is oval would have something to do with this. also many of the factory chinese tires are complete crap,and are out of round brand new.
puta
Post by puta on Nov 26, 2017 22:05:31 GMT -5
HELLO I'M JUST WONDERING WHY MY SCOOTER PRODUCE SO MUCH VIBRATION EVEN THOUGH ALL SCREWS WE'RE TIGHTEN SO MUCH... I DON'T KNOW WHAT TO DO IN MY SCOOTER TO HAVE SMOOTH RIDE.....
Post by lostforawhile on Nov 26, 2017 23:28:36 GMT -5
Maybe the bent rear wheel you have? You said it was oval shaped
puta
Post by puta on Nov 27, 2017 2:07:04 GMT -5
Mmmmm i think it is the whole engine...
Post by lostforawhile on Nov 27, 2017 12:17:55 GMT -5
You post your rear wheel is oval, then you post you can't figure out why it vibrates,then you blame the engine? It's probably leaking oil and breaking things, because your bent rear wheel is jackhammering it to death. Keep riding it with a bent rear wheel, and it's eventually go to fracture the rim, then you won't have to worry about the engine anymore, after the scooter goes out of control, because your rear wheel passed you.
Post by greginisn on Nov 29, 2017 16:26:37 GMT -5
HELLO I'M JUST WONDERING WHY MY SCOOTER PRODUCE SO MUCH VIBRATION EVEN THOUGH ALL SCREWS WE'RE TIGHTEN SO MUCH... I DON'T KNOW WHAT TO DO IN MY SCOOTER TO HAVE SMOOTH RIDE..... It would be helpful for you to answer the questions, it does help to aid in troubleshooting your problem. So far a bent or oval rear tire or wheel. I have been in cars with unbalanced rear tires and the entire car would shake at road speeds, why wouldn't a ~200lb scooter do the same thing. You are still dealing with that issue I think since you never mentioned it being fixed? Greg
