Post by milly on Nov 24, 2017 15:40:05 GMT -5
I have a 125 version here in the U.K. I would like to change it to 150 same as you have in the U.S. I am not after a superduper go faster kit just a standard cylinder and head set so I don't over stress the crank as I hear they need upgraded with higher performance set up. I don't think I can get much standard stuff here in UK.
I am also confused between 3 port and 5 port not knowing what mine is. It's a 2010 model. I wonder also what the jet sizes will need to be. Any help gratefully appreciated
Post by greginisn on Nov 26, 2017 3:36:48 GMT -5
Milly,
Judging by the weak response to your question, maybe you should check into the “modernbuddy.com” forum? They might be able to help you with the stella question there. There is also a series of stella videos on youtube but not sure if they would be helpful or not. But might be worth a look?
Good luck, Greg
Post by milly on Nov 26, 2017 5:04:52 GMT -5
Thankyou Greg, have just posted on there 😊
