puta
Post by puta on Nov 26, 2017 11:59:44 GMT -5
My Friend is using my Yamaha beluga/ca50 a while ago.... then i'm just behind him.. then he full the throttle then suddenly when he is far from me, i saw him that he is slow and the engine abruptly stop... i tried to do something just to start it again but nothing is happen...
What do you think is the reason why my Engine stop, is it Overheating or something went wrong inside the Engine? I'm wondering why it's hard to start.. WHAT SHOULD I DO TO AVOID THIS PROBLEM? TELL ME SOME TIPS AND TELL ME WHAT ARE THE MAINTENANCE SHOULD I DO TO MAKE MY SCOOTER IN A GOOD CONDITION?
Thank you!!!☺
Post by diynuke on Nov 26, 2017 14:58:10 GMT -5
sound like the engine is not getting oil 2 stroke's of course need oil to keep running otherwise they will seize up
so i guess oil pump broken or something related to that. atleast if it is a 2 stroke but i searched it up really quick so yeah xD
Post by 90GTVert on Nov 26, 2017 19:50:34 GMT -5
Have you tried restarting it recently? Sometimes 2Ts will soft seize. They got hot and seize and then will start once the engine cools. It's most often caused by running lean. More than likely too small of a main jet since it was at WOT.
If it still won't start, check compression.
puta
Post by puta on Nov 26, 2017 21:09:36 GMT -5
What if the compression is still the same... and nothing change.. but in the moment that i start up my engine i remove the air cleaner. And i notice the carb is blowing smoke while kicking the kick start
Post by oldgeek on Nov 26, 2017 21:20:06 GMT -5
All advice given so far is good and needs to be checked. Another possibility is that the flywheel moved on the crank (came loose), throwing ignition timing off, or possibly the reeds are bad, if it has reeds.
Post by 90GTVert on Nov 27, 2017 6:08:58 GMT -5
What if the compression is still the same... and nothing change.. but in the moment that i start up my engine i remove the air cleaner. And i notice the carb is blowing smoke while kicking the kick start If compression is the same, then maybe your cylinder/piston are alright and you'll need to look elsewhere. Could be fuel vapor coming from the carb. Maybe bad reed valves.
puta
Post by puta on Nov 27, 2017 7:55:27 GMT -5
Mmm thanks admin
