mpfine
WOT WOT WOT
Post by mpfine on Nov 28, 2017 15:16:58 GMT -5
Would I be risking some level of cylinder or other damage if I ran my Jog 50cc on one ring? If I can get away with it for a bit, which slot should I put the one ring in? Upper or lower?
Post by 90GTVert on Nov 28, 2017 15:39:51 GMT -5
It could be done. It was discussed here in depth quite a long time ago, but I can't seem to dig that up ATM. The ring would go in the slot nearest the crown. You'd likely lose some low end power from poor sealing and possibly gain a little at high RPM from less frictional losses. The open space where the 2nd ring should be could cause some short circuiting. Accelerated wear would be expected. It's something that I'd only try for racing/performance experimentation or in an "emergency" when I had no other choice.
mpfine
WOT WOT WOT
Post by mpfine on Nov 28, 2017 18:47:46 GMT -5
Thank you. Good points. I'll work on being patient. I don't want to cost myself more than necessary.
