Post by dav3titus on Dec 3, 2017 18:30:52 GMT -5
I have a 2015 Taotao Quantum 150cc. It idles,runs fine until I hit 37 mph, then it starts to backfire and lose power. If I let off the gas ,and it slows down it recovers, I can go no faster than 37. Help!!
Post by 90GTVert on Dec 4, 2017 5:51:36 GMT -5
How does it do if you are wide open throttle from a lower speed? Run fine till 37, or poor performance there too? Do you have a tach to know if there's a specific RPM associated with this issue?
Post by dav3titus on Dec 4, 2017 17:22:44 GMT -5
I'll see what happens.
Post by tortoise2 on Dec 4, 2017 21:57:00 GMT -5
Post by rocketdog on Dec 29, 2017 0:47:40 GMT -5
Check out your fuel delivery. Make sure the petcock, fuel line, and fuel filter are ok. Sounds like your running out of fuel. If that isn't it that your coil could be breaking down. If it doesn't do it all the time, but only when it's hot, it may be that. Kinda hard to diagnose a problem online. Even with videos.
