Post by 88jog on Dec 4, 2017 21:24:46 GMT -5
So, a little background first.
I have a 1988 Yamaha Jog CG50. I got it in 1999 and used it in college. It's a US model so the speedometer display is calibrated in MPH. About a year later I let someone drive it and they managed to crash, so I rebuilt it. My memory is a little hazy, but I replaced the speedo cable and/or replaced the front wheel with items purchased on ebay and scrap yards.
I recently got the urge to get it running after about 10 years of storage, and managed to do so pretty easily. But I realized that the speedometer needle is actually pointing to kph on the mph scale. In other words, if I'm driving at 20 mph the speedo needle would be pointing to 32 mph which is how fast I'm actually going in kph. If I move at top speed (variator shim removed, 43 mph by GPS) the needle is bottomed out at the bottom of the speedo.
This is annoying, and I'd like to fix it the easiest way possible. It also adds extra miles to the odometer every time I drive it.
Can someone tell me how I screwed up when I rebuilt the scoot, and what the cheapest/easiest way to fix the issue would be?
I'm assuming something is messed up with the speedo gearing in the wheel hub. Maybe I put a kph wheel on a mph scoot if I replaced the wheel? I dont think I replaced the wheel though, it appears to still have the original white rims on it which I repainted flat black (looks badass). I know I bought a pair of purple wheels from a 90's model CY50 Jog on ebay, which I only used for the tires, as the purple wheels are still in the shed. Maybe I moved the speedo gear from the purple wheels to the original wheels? Would it be possible to mess this up with just the speedo cable which I think I purchased at a scooter salvage yard or possibly ebay as well?
Also, I'm in the process of tuning the carb for a pod filter, and have to increase the main jet size. I managed to find a 77.5 locally, but I don't know what the factory main jet is for a starting point as it is unmarked. Anyone know what the factory jet size is?
Thanks, and if possible part numbers for the speedo fix would be useful.
