Post by lostforawhile on Dec 16, 2017 3:36:42 GMT -5
I've having very minor idle issues, sometimes the idle is ok, sometimes I have to keep bumping the throttle, I'm running a 41 pilot, and I've got the screw turned out about 1 1/4 turns. it's running fine otherwise, other then the wild temp swings in the weather, we are going from the low 30's to mid 60's in a day, I'm running an 86 at the moment, for a main, it runs better towards freezing, I can pick up almost 5 mph, because of the denser air leaning out the mixture a bit, I wish there was a jet in between, but no such luck, I'm afraid if I ran an 85, it would lean out too much when it was cold. I'm going to ride out to Berlin in the morning,so I may fiddle with the idle speed and see what it does. 350 miles in the past week, and so far it's doing good
Post by FrankenMech on Dec 16, 2017 15:50:12 GMT -5
