Post by pete130 on Dec 17, 2017 5:00:55 GMT -5
I went to do my bottom end today aerox 100cc put crank in fridge over night meat locker not quite a freezer. Just to see how close bearing was to fitting as i read to try with crank cold and bearing room temp and bearing slide on with no trouble thinking crank would swell to bind bearing and it still falls off when at room temperature this is not good i can get a tink when looking for play way to much it not the right size as part number on it have to send back and get refund start again ebay i seem to have a lot of trouble with shipments lately anyway am i wrong to think this is not a brand new bearing and if it is well should have come sealed in box but came in clip seal lunch bag lol should have know hay well build is on hold till i sort out
Post by 90GTVert on Dec 17, 2017 5:53:07 GMT -5
If you have precision measuring tools, you could check bearing ID and the diameter where it rides on the crank to be sure the bearing is the issue.
Post by pete130 on Dec 18, 2017 4:41:43 GMT -5
Yes thats a great idea and i have done hers a pick of bearing size room temp it turns out not good sent back for refund cost me $25 to send back to get refund ebay not good but went and git ntn's today and doung install as i type heating bearings now lol
Post by pete130 on Dec 18, 2017 4:42:52 GMT -5
Dont worrie will remove cloth soon just soaking up grease thats in then new lol
