Post by pete130 on Dec 22, 2017 15:48:41 GMT -5
I got hold of a turbokit pipe my problem is it is made for my ride but i have bbk and exaurst port flange needs to be 28mm problem is header is 25mm heres a photo ive marked the size needed i know i can just gring out to size. But knowing header pipe length is important at least it wont have a step restricting flow but will reduce size quickly then enlarges again next pice of pipe spection thoughts
Post by pete130 on Dec 22, 2017 15:49:45 GMT -5
This is rhe header pipe
Post by 190mech on Dec 22, 2017 18:32:17 GMT -5
That is a horrible head pipe!!!A 2stroke should have a smooth tapering headpipe,that one is s**t...Perhaps a better pipe can be found and modified to get you some decent power..Once you get the engine together,get me the port durations and I will calculate some reasonable pipe dimensions,then we could search for a good alternative..
Post by ryan_ott on Dec 22, 2017 21:43:35 GMT -5
Not to mention all that loose rust getting shoved back into the motor likely won’t have a happy ending.
Post by pete130 on Dec 23, 2017 3:05:00 GMT -5
Yer i know i payed for a hypa race payed €300 and this is what i was sent not good hay and for turbokit someone at factory swaped this is waht i was ment to get big difference I email turbokit they were more intrested in tell me i know nothing its the same pipe just not cromed we will give you €35 refund what a joke the pipe i waited 7 weeks to be so called made turned into a very stressfull ordeal i got my money back and told to keep and you can see why they said keep i think it was a 2nd out of bin made by newbie its a joke i want to just get something good but hard to get for size of motor can get hand made for 130cc to bolt on $250usd $300-325 aud was very pissed off when i opened box that was right they wouldnt do a thing there hebo too i was very suprised what about a RS2 100cc what u think the pipe i have is shit but its that or stock and ivr got a sleeper pipe bet it would run better a subject im not fond about lol Its now port matched and 28mm but better than nothing till i can get new one
Post by pete130 on Dec 23, 2017 3:06:36 GMT -5
Was thinking for pulling apart and acid was inside till clean but you just dont know may just keep and put on 50cc when i clean it up
Post by pete130 on Dec 23, 2017 4:00:35 GMT -5
This is the only part worth keeping header needs to be fully replased at least or new pipe i agree this is the body of pipe
Post by 190mech on Dec 23, 2017 6:01:29 GMT -5
Post by pete130 on Dec 23, 2017 20:14:57 GMT -5
Yes your right about that and i do want a tuned pipe not rubbish the only pipes i could find were the one you see but thats not what i payed for and the RS2 or Endy extrem and there a ebay pipe made for bws 4vp motor for 130cc big bore looked good well made and no restrictions with pressher springs half way doen headder any of the above would have been a better pipe but thats what i got sent ok its free now got refund but what to do with it
Post by pete130 on Dec 23, 2017 22:16:38 GMT -5
Was looking at this pipe i know its a cheapie but hay better than what i have Thinking better to take the great advice i get from here and get timing numbers and post to get tuned pipe spec and have or make my self i hope thank all
Post by pete130 on Dec 23, 2017 22:17:25 GMT -5
Its rated to 11000rpm and has rhe 28mm header i need
Post by pete130 on Dec 24, 2017 0:09:32 GMT -5
Bore-Up for 130cc- Exhaust Chamber Φ120mm, Exhaust Flange Inner Diameter Φ32mm Corresponding product to the most kind of Tuning Engine and Big Bore Engine for Bore-Up 120cc-130cc Exhaust Chamber Φ110mm, Exhaust Flange Inner Diameter Φ29mm Tuning Engine, Big Bore Correspondence. Unusable for Standard Driving for Standard 100cc Bore-Up 120cc Exhaust Chamber Φ100mm, Exhaust Flange Inner Diameter Φ28mm From Standard 100cc to 120cc of Bore-Up Engine Correspondence This product Best Match to JOG Series about 100cc Bore-Up Engine!
Only problem $770 nice but expencice made for 130cc aerox what i would like but to much may as well get a windjammer lol
Post by 190mech on Dec 24, 2017 5:47:25 GMT -5
The first pipe you posted looks like a good street pipe,the stinger ID should be at least 21mm...
Post by pete130 on Dec 28, 2017 1:09:41 GMT -5
I gave the pipe i had a acid rinse with stright acid all the inside cleaneded up good just rinsed a few times till clean acid came out was rusty tge first 2 rinces and wd40 it big time lol and then a coat of 2t oil all inside of course going to have to use to run in dont have the cash to buy new at moment on the list next
Post by pete130 on Dec 28, 2017 1:12:00 GMT -5
And i port matched it to 28mm of exuarst port
