Post by damian on Dec 27, 2017 0:55:34 GMT -5
My taotao will start but afterwards always dies very quickly no matter how much gas I give it. Does not want to idle. Any suggestions?
Post by jeff84 on Dec 27, 2017 2:02:26 GMT -5
I would start by inspecting the fuel system. replacing/adding a fuel filter etc., and cleaning the carb. if that doesn't work adjust your valves.
how new or old is the scooter? or even ore important, how old is the gas in the tank? any additional info you can give might help.
if you ride regularly and the problem came on gradually I would start with a valve adjustment.
Post by damian on Dec 27, 2017 23:42:21 GMT -5
The I got bad gas in it a month ago so I cleaned out the carb and got all the gas out. Now I have 5 day old gas in the scooter but it doesn't want to stay running. I got a new fuel filter and the spark is good. New hoses. How do you adjust the valves
Post by tocoo on Dec 28, 2017 3:50:42 GMT -5
The I got bad gas in it a month ago so I cleaned out the carb and got all the gas out. Now I have 5 day old gas in the scooter but it doesn't want to stay running. I got a new fuel filter and the spark is good. New hoses. How do you adjust the valves www.youtube.com/watch?v=5vl1mrTVCQ0
Post by pinkscoot on Dec 28, 2017 11:53:32 GMT -5
