Post by triumphmad on Dec 29, 2017 5:16:38 GMT -5
My Peugeot Blaster is very hard to start in the morning. Once I give it a spray of engine starter it fires up straight away. The rest of that day it starts fine. It’s running a 70cckit, 21mm carb, open filter & technigas pipe.Any ideas.😢
Post by ThaiGyro on Dec 29, 2017 6:59:32 GMT -5
Haha...My initial response is to start with the fundamentals of carb tuning. (Assumes you have changed nothing lately). 1. New air filter, spark plug, clean fresh fuel 2. Check/Set float level and re-new float needle 3. Pilot jet sizing and adjustment 4. Needle valve step adjusting 5. Main jet sizing and testing
My political response is: Consider going back to an air box. (2 stage) Especially, if you live in conditions that change frequently. I live in hot and humid 80% of the time...and still play with tuning often. I have tuned long enough to know not to give up my air box. Opinions vary with riding style and performance demand. Pods are good for top end...IMO, only top end. Low end and mid range are greatly enhanced by controlling air pressure at the carb venturi...stabilizing it.
If you live in a cold area this time of year, but hot in summer...it makes a big difference in carb settings. That difference is a bit amplified with a pod filter. (Plus it is less fuel efficient)
Post by triumphmad on Dec 29, 2017 16:34:38 GMT -5
Ok. I think I’ll start with a new plug. The bike is my daily ride & has great performance overall so just need to sort the cold start. Maybe a pilot jet adjustment is need. It has a manual choke so I know that’s working. Thinking it needs to be richer on the start up.
Post by lostforawhile on Dec 29, 2017 18:12:58 GMT -5
change the plug and put the airbox back on, has it been cold? sometimes with these scoots you need to start them with the kick starter first thing in the morning, it spins the engine over faster then a cold battery and starter, most of these also use 15w40 diesel oil,which is really thick when cold, so an initial kickstart to get some engine heat,helps
Post by lostforawhile on Dec 29, 2017 18:14:07 GMT -5
edit didn't see 2 stroke, ignore the oil issue
Post by ThaiGyro on Dec 29, 2017 18:41:23 GMT -5
edit didn't see 2 stroke, ignore the oil issue Actually lostforawhile has a point worth pondering...if you ARE in cold weather and still have an oil injection pump the 2T oil will not pump as easily just as suggested . It might take a few minutes for it to begin to work well. Yet another reason to make a paper weight out of that old sick pump and consider going to pre-mix. With your oil dissolved in the fuel, no glue! I think your issues are carb tuning though...
Post by triumphmad on Dec 31, 2017 23:15:41 GMT -5
Thanks for the ideas. It is now summer here so even in the morning it’s not that cold. I always use the kick start & the bike uses premix already.
Post by aeroxbud on Jan 1, 2018 19:21:51 GMT -5
If it has an auto choke, have you checked its working?
Post by triumphmad on Jan 1, 2018 20:35:44 GMT -5
Has a 21mm carb with a manual choke.
Post by triumphmad on Jan 1, 2018 21:51:24 GMT -5
Fitted a new plug & it started straight up. May start cleaning my plugs every few weeks.
Post by kkzxxx on Jan 2, 2018 5:33:06 GMT -5
Fitted a new plug & it started straight up. May start cleaning my plugs every few weeks. Or start using a hotter plug, from 9 to 8 for an example.
Post by ThaiGyro on Jan 2, 2018 8:55:50 GMT -5
Fitted a new plug & it started straight up. May start cleaning my plugs every few weeks. Or start using a hotter plug, from 9 to 8 for an example. Good point...plus, if you have had even mild performance issues for a bit of time...consider a through exhaust port and pipe cleaning...Good time for it!
Post by RollingThunder on Jan 2, 2018 18:55:58 GMT -5
Fitted a new plug & it started straight up. May start cleaning my plugs every few weeks. Or start using a hotter plug, from 9 to 8 for an example. I would recommend fixing whatever issue is causing the plugs to foul instead of going to a hotter plug. It might be worth while to take another look at your jetting.
