Post by aaronj863 on Dec 29, 2017 14:59:38 GMT -5
my right turn signal works fine but then i turn on the left the running lights and tail light flash instead of the signals the front only lights up a little dim and the back doesnt turn on at all. is it a blown bulb or the flasher relay messed up?
Post by 90GTVert on Dec 29, 2017 15:08:55 GMT -5
I'd start with the easy one and check the bulb first. If one side works, I'd expect the flasher to be fine. Possibly a wiring issue or short, but again I'd try to replace the bulb first or check it.
Post by lostforawhile on Dec 29, 2017 15:58:40 GMT -5
bad ground, it's finding a loop through the other bulbs.
Post by aaronj863 on Dec 29, 2017 20:47:17 GMT -5
found the problem the little plastic spacer where the positive wire is in the middle that rides on top of the spring was broken and the wire was grounding out, i had a replacement and spliced it in from a parts bike and fixed the problem. thanks for the suggestions.
