Post by johnnyfierce on Dec 30, 2017 5:43:51 GMT -5
Starting issue with key ignition/push start. Clock shows till key is turned to on position, then it dies. Push start WON'T work, BUT it will kick start fine. Fuse connector on hot line is good. After cranked lights work as if all is well. Is this an shot ignition switch?
Post by RustyPop on Dec 30, 2017 7:55:59 GMT -5
Starting issue with key ignition/push start. Clock shows till key is turned to on position, then it dies. Push start WON'T work, BUT it will kick start fine. Fuse connector on hot line is good. After cranked lights work as if all is well. Is this an shot ignition switch? If you have a DC CDI and the battery is in poor condition, it might be the problem
Post by johnnyfierce on Dec 30, 2017 10:43:52 GMT -5
Changed out to new battery and that was exactly the problem, i had suspected such. thx for the help, mission successful!
Post by pinkscoot on Dec 30, 2017 13:29:37 GMT -5
Johnny. Thanks for letting us know the solution. It's always good when its an easy fix.
