Post by milly on Jan 1, 2018 22:20:41 GMT -5
I presume the above 50cc 4t oil pump has a gasket. If so what does it look like as I don't have a pump close to hand to match one to in the set I got. Thankyou
Post by GrumpyUnk on Jan 3, 2018 10:07:24 GMT -5
I just used duck duck and goog to search for images thusly: "139qmb oil pump"
Got a LOT of peekshures. There may not be a gasket if the machined surfaces are smooth enough.
I have not taken one apart to verify that there is or is not a gasket.
Just looked at the pdf, and there are two O-rings, no gasket. The PDF has good illustrations. Title: 139QMB_Engine_Manual.PDF I think it is on this site, but you can search if not. tom
Post by milly on Jan 4, 2018 2:54:58 GMT -5
Thankyou very much for the info Tom.
Post by fortyeight on Jan 17, 2018 17:39:41 GMT -5
once the o ring as been losend it wont reseal it,make a paper gasket out of gasket paper leaving the o rings on and coat the paper gasket in oil and put back together
