Post by magoconnor on Jan 8, 2018 19:22:37 GMT -5
Post by magoconnor on Jan 8, 2018 20:30:26 GMT -5
Anyone?
Post by ryan_ott on Jan 8, 2018 20:36:29 GMT -5
Single wire coils use the metal base as the ground, 2 wire coils have a positive and negative side. If you wanted to swap to a 2 wire coil just take the negative terminal to the frame mounting point. So yes you could swap coils as long as you have room to mount it.
Post by magoconnor on Jan 8, 2018 20:41:09 GMT -5
Thanks man.
So I just run the green pin straight to the frame/ground ?
Post by ryan_ott on Jan 8, 2018 21:09:50 GMT -5
Yes green should be the ground to frame.
