luka
Scoot Junior
Post by luka on Jan 18, 2018 4:47:36 GMT -5
Hi,
Could anyone give me any advice on how to de-restrict a Baotian BT49QT (Chinese Lexmoto Scout Pulse to be exact)
Thanks
Luke
Post by aeroxbud on Jan 18, 2018 6:14:59 GMT -5
There is a pink wire under the right hand rear side panel. This needs to be disconnected. Then tape up the ends. You next have to move the needle in the carb to the middle position. Some are also restricted by a washer in the variator, but most are not
Post by edwardtennant on Jan 18, 2018 7:03:13 GMT -5
I have this bike (Pulse Variant) and to restricted it I had to remove the pink wire going to the CDI, then remove the metal restrict or plate in the air box to choke the engine, move the needle in the carb up to the middle notch, Remove a metal restrictor ring in the CVT on the front pulley (Variator). While i was there i put in new 5G Roller weights in, not sure if necessary but i did it anyway.
After that i was getting a top speed of around 40MPh (on Spedometer) on a flat.
Next i put in a Narkau drive belt and got an extra couple of MPH
Post by 90GTVert on Jan 18, 2018 8:31:11 GMT -5
If you can get to around 35MPH, it may not even be restricted.
