Post by magoconnor on Jan 21, 2018 20:51:27 GMT -5
Hello. I bought a new set 12" tires of a used baotian. The bearings are bad, so I need to replace them. The problem is, I dont know which model the came from! So i'm not sure exactly what size i need.
I dont want to take the wheels of the bike, before i can get some new ones ( but maybe I have to)
Post by bluegoatwoods on Jan 21, 2018 21:30:50 GMT -5
It might be that you have to remove the wheel first, I guess.
The reason is that the only way I can think of for you to get new bearings would be to get measurements of inside diameter, outside diameter and 'depth'. Take that to a bearing shop and have them line you up with something that's automotive quality.
The good news is that it'll probably be pretty cheap.
Post by 90GTVert on Jan 21, 2018 21:53:09 GMT -5
To be certain, you either need to find numbers on the sides of the bearings or measure the ID, OD, and thickness of the bearings.
