Post by xtirex on Jan 27, 2018 13:03:32 GMT -5
Post by 90GTVert on Jan 27, 2018 14:27:05 GMT -5
You can use a clutch of a different size, but you'd need to get a matching pair of clutch and bell. You can't put a 107mm clutch inside of a 112mm bell. Well, I guess you can, but it won't work very well. So, get a 107mm clutch and 107mm bell or just get a clutch to match the size of your current bell.
I've never used that Motoforce clutch, but I had an MRP that looked just like it. Actually 2. The first one broke in short order on a mild/sport 70cc. The second was some other branding, but seemed the same as the first... other than it didn't break a shoe off quickly. They got the revs up more than stock for me, but I never used them much because the higher engagement and increased slip that I had made the stock clutches more appealing to me. I've never owned any of the more expensive clutches to tell you much about them or how these budget sport clutches compare.
Post by paydem on Jan 27, 2018 14:40:40 GMT -5
I'd say don't buy that clutch. Cheap. If it broke on a mild 70cc setup, I expect it not to be reliable on a 70cc Racing cylinder. Get a Malossi Delta or a Stage6 Torque Control clutch...
Post by xtirex on Jan 27, 2018 18:35:52 GMT -5
Hmm.. okay.. thanks for all info. Didn't know you couldn't use a smaller clutch in bigger bell.. hah.. but yeah its logical. Will take a little more time and put some more money on the side so i can buy stage6 or malossi one. Thanks again both of you guys. btw 90GTVert love your videos on yt!
Post by ThomasTPFL on Jan 29, 2018 11:25:03 GMT -5
I'm a fan of the Malossi Delta if for no other reason it makes swapping clutch springs so much easier.
