Post by magoconnor on Feb 2, 2018 22:58:17 GMT -5
Post by Happypancake! on Feb 3, 2018 9:20:48 GMT -5
I've experimented and found good results. 15" from the filter to the intake valve seems to be ideal. Where did you find the spacer?
Post by magoconnor on Feb 3, 2018 10:41:20 GMT -5
Cool Stuff, have you tried raiseing the intake manifold? What size carb are you running? What size bore diameter? stock head?
Post by Happypancake! on Feb 3, 2018 17:40:19 GMT -5
The stock Met/Ruck carb for the 49cc is 18mm. My 58cc Met w/ cam upgrade has a Keihin PC20 - 22mm. The PC10 is also 22mm.
