Post by magoconnor on Feb 5, 2018 14:49:49 GMT -5
Hello. How do you change the rear wheel bearings, on a 139qmb? And are the front wheel bearings, the same as the rear?
Post by mrhooper on Feb 5, 2018 16:14:48 GMT -5
There is no rear bearings in a qmb139 wheel itself. The rear wheel is power thru a splined shaft. The front wheels have bearing the that can be removed with a punch. Take a punch and hammer and hit the bearing from the back side to push it out of the wheel. Use a socket the fits the outside ring and use a mallet to tap it in gentley to the wheel.
Post by 90GTVert on Feb 5, 2018 17:07:25 GMT -5
