Post by drbob on Feb 8, 2018 13:07:04 GMT -5
My oil tank busted and wont hold oil. Can i just block The hose off that was at the bottom of the tank and start premixing?? Need Lke asap
Post by 90GTVert on Feb 8, 2018 14:07:58 GMT -5
I take all of the junk out when I premix. Some just connect the pump's inlet and outlet with a hose and don't do anything else. Some block off the ports on the pump or connect them and then remove the drive gear so it's not turning. 32:1 - 40:1 are common safe pre-mix ratios and some oils do fine at 50:1. 49ccscoot.proboards.com/thread/564
Post by drbob on Feb 8, 2018 14:09:09 GMT -5
But am i basically able to just quit using the oil tank and start added premixed gas??
Post by ThomasTPFL on Feb 8, 2018 14:21:49 GMT -5
Pretty much, yeah.
Post by drbob on Feb 8, 2018 14:28:00 GMT -5
Ive planned on switching soon since i noticed the air filter having excess oil in it so with this hose breaking and unable to reach the tank now i figure might as well switch now. I just need to drive to work tonight and dont want to do extra work in the freezing weather that isnt needed
Post by islandscrub on Feb 8, 2018 15:24:59 GMT -5
Connect the inlet to the outlet, my god, genius. Simple, but that never crossed my mind as a solution D:
Post by ThomasTPFL on Feb 8, 2018 17:08:57 GMT -5
And cap where it feeds into the carb.
Post by maker1to2 on Jul 6, 2018 20:29:59 GMT -5
Quick question what is a safe prefix ratio for a 72 polini kit with a malossi full crank During the Break in period to after
Post by ThomasTPFL on Jul 6, 2018 20:41:19 GMT -5
The Corsa kit paperwork recommends 3%
Post by maker1to2 on Jul 6, 2018 21:22:39 GMT -5
Alright 32:1; 4 oz per gallon..much appreciated thought it was around 4 per. Had to make sure; the paper is long gone: it has to be done !!!!!
Post by milly on Jul 21, 2018 13:07:12 GMT -5
But am i basically able to just quit using the oil tank and start added premixed gas?? If I remember reading rightly you have to increase your main jet size as well now it is running oil and petrol mix drbob
