Post by nuclearchrist on Feb 18, 2018 14:04:33 GMT -5
Hey guys. I have a question here. Can a coil off a taotao work on a jonway 50cc?
Post by tortoise2 on Feb 18, 2018 14:14:03 GMT -5
Post by nuclearchrist on Feb 18, 2018 14:17:08 GMT -5
Yeah, they look the same a fit the spark plug just the same.
Post by nuclearchrist on Feb 18, 2018 14:47:10 GMT -5
Trying to add pictures but don't know how
Post by nuclearchrist on Feb 18, 2018 14:59:51 GMT -5
Here are a few pictures I took. The black plastic one is off the jonway, and metal one os off the taotao imgur.com/a/jg4gW
Post by greginisn on Feb 19, 2018 6:23:11 GMT -5
I'd say go for it. They look very similar. Nothing mystical about a coil anyway. Some guys put late model Ford COP type coils on their GY6 scoots with good results.
Plug and scoot.
Greg
Post by GrumpyUnk on Feb 21, 2018 16:03:39 GMT -5
The coils are totally swappable. They both run from the same type of CDI unit, and operate a spark plug which is exactly the same, brand name being excluded. All the replacements from various vendors are not brand specific, so you can mix and match as you wish. Only caveat is DC vs AC CDI modules. tom
Post by mrkswthwrth on Feb 27, 2018 8:18:31 GMT -5
FWIW, i swapped a cr85 coil into my old 50cc and it was direct fit, had a stronger spark and easier starts than the junky old chinese one i was using.
Post by tocoo on Mar 1, 2018 3:01:42 GMT -5
FWIW, i swapped a cr85 coil into my old 50cc and it was direct fit, had a stronger spark and easier starts than the junky old chinese one i was using. this coil is like this ? if so it seems more horizontal than vertical like the coil for the chinese scooter. how did you attach this coil to the frame? Where is the the second connector to plug the electrical wire [my coil has a green end and a black end I believe], but on the picture, there is only one end]
Post by 90GTVert on Mar 1, 2018 5:54:52 GMT -5
if so it seems more horizontal than vertical like the coil for the chinese scooter. how did you attach this coil to the frame? Where is the the second connector to plug the electrical wire [my coil has a green end and a black end I believe], but on the picture, there is only one end] You can bolt that coil on through one of the holes in the metal part. That's what you need to ground as well. Sometimes they're just grounded by being bolted to the frame. You can put a ring terminal on the ground wire to your old coil on the bolt where it attaches to the frame.
Post by mrkswthwrth on Mar 1, 2018 7:20:56 GMT -5
I made a short adaptor wire to go from a male blade to a ring terminal. Connected to ground wire for coil. Ran the mounting bolt through the ring and the ground on the coil. Connected positive as normal.
Gave me a stronger spark, and if i ever wanted to switch to a standard coil it was a plug and play affair.
Post by lilpinny on Mar 1, 2018 16:29:51 GMT -5
