Post by zummerp on Feb 26, 2018 12:49:34 GMT -5
Hey guys - I recently got a Flyscooter's Il Bello, 2008, 50cc (appears that it is made by Znen) and it is missing the center stand. I have tried finding a replacement but can't figure out what type it *should* be. I replaced the stock engine with a GY6 49cc and my life would be a lot easier if I could find a stand! Any tips on which one to buy and where to find it? Thanks so much in advance!
Post by tortoise2 on Feb 26, 2018 13:50:42 GMT -5
replaced the stock engine with a GY6 49cc Why would a 139QMB center stand NOT work?
Post by zummerp on Feb 26, 2018 14:19:34 GMT -5
I don't see a reason why it wouldn't work, but wasn't sure where to find one or what else I needed for it? I noticed that most online specified sizes and/or said a Type 1 or Type 2 spring was required. I just don't want to order the wrong thing and a center stand is definitely new for me!
Post by zummerp on Feb 26, 2018 15:01:25 GMT -5
Does this look right? Thanks!
Post by pinkscoot on Feb 26, 2018 15:12:00 GMT -5
Most center stands use 2 springs. A small one inside a larger one.
Post by dexameth on Feb 28, 2018 15:08:05 GMT -5
Hey, I did a little looking for you. Check this link right here. You'll need the springs and rubber bumper too, which are there as well. The measurements are there too for you to size it up.
Post by zummerp on Mar 1, 2018 16:56:14 GMT -5
Got the center stand in place and lock pin installed... now I can’t for the life of me stretch this spring! Is there a special tool or any tips for getting this thing attached?!?! I’ve tried a screwdriver and it won’t budge.
Post by tortoise2 on Mar 1, 2018 17:12:58 GMT -5
I’ve tried a screwdriver and it won’t budge. Phillips screwdriver technique link.
Post by zummerp on Mar 1, 2018 17:43:21 GMT -5
I’ve tried a screwdriver and it won’t budge. Phillips screwdriver technique link. Wow! That worked perfect!!!! After all these years I have a center stand.
Post by dexameth on Mar 2, 2018 8:38:00 GMT -5
Careful leaning into sharp turns now... I took mine off because I would scrape in round-abouts... didn't wanna high-side. Good work with that spring thought!!
Post by tocoo on Mar 3, 2018 7:15:32 GMT -5
Phillips screwdriver technique link. Wow! That worked perfect!!!! After all these years I have a center stand. is this the technique mentioned ? youtu.be/JxiBYdBx1GA?t=111
Post by tocoo on Mar 3, 2018 11:49:17 GMT -5
here is another video with -metal wire -spring plier
