Post by starclap92 on Mar 4, 2018 9:38:11 GMT -5
Hi, im having a hard time finding an issue with my bike. It only happened once so far but i want to fix the issue so it dont reoccur. I tried starting my bike at work yesterday, Put the key in, pulled the brakes, and pressed the electric start. It made a click noise and then the lights and everything went off. Went back in to get some tools and tried one more time. This time i kick started it. Fired right up. I got home and checked the fuses, battery cables, and the battery charge. All checked out alright. Any suggestions?
Post by jmkjr72 on Mar 4, 2018 9:55:15 GMT -5
If all the wording is good and not shorts or bad connections next would be to double check all the switches If all that checks out good check the relay and the starter More often then not I have found wiring or bad Swift with just the click (iffy side stand switch’s if equipment)
Post by lilpinny on Mar 4, 2018 10:43:50 GMT -5
Also check the voltage drop on the battery. Hook it up to a multi meter and start it. The voltage will drop and come back up real quick. If it drops below 9 the battery is bad. Then while its idling it should be around 13.4. then you know your charging system is working.
Post by starclap92 on Mar 4, 2018 11:10:40 GMT -5
Also check the voltage drop on the battery. Hook it up to a multi meter and start it. The voltage will drop and come back up real quick. If it drops below 9 the battery is bad. Then while its idling it should be around 13.4. then you know your charging system is working. I totally forgot about that
Post by starclap92 on Mar 4, 2018 11:11:32 GMT -5
If all the wording is good and not shorts or bad connections next would be to double check all the switches If all that checks out good check the relay and the starter More often then not I have found wiring or bad Swift with just the click (iffy side stand switch’s if equipment) Good advice i didnt check that
Post by tortoise2 on Mar 4, 2018 12:26:02 GMT -5
Year, brand, model, engine size, modifications?
Post by starclap92 on Mar 4, 2018 12:28:32 GMT -5
Year, brand, model, 2 or 4-stroke engine, modifications? Tao tao quantum 150
Post by jackrides on Mar 4, 2018 13:58:52 GMT -5
Spray clean with electric contact cleaner all starter related connections. After spraying, plug/unplug or switch on/off several times.
Post by starclap92 on Mar 4, 2018 14:00:31 GMT -5
Spray clean with electric contact cleaner all starter related connections. After spraying, plug/unplug or switch on/off several times. Ill try that as well
Post by pinkscoot on Mar 4, 2018 17:16:06 GMT -5
Did you check your kill switch? Are the connections on the battery tight? Check the engine ground cable. or any of the things listed above.
Post by starclap92 on Mar 4, 2018 17:22:35 GMT -5
Did you check your kill switch? Are the connections on the battery tight? Check the engine ground cable. or any of the things listed above. Never checked the kill switch either ill have to go over all these things this week. I appreciate it
Post by greginisn on Mar 4, 2018 23:15:30 GMT -5
Check for a voltage drop across the large connections of the starter solenoid. You should see no significant voltage there when start button is pushed.
Greg
Post by starclap92 on Mar 5, 2018 6:45:23 GMT -5
Oh and another problem i have is when everytime i fill up it takes a couple tries with the throttle opened to start it goes off(with lights on) and keeps stalling?
Post by pinkscoot on Mar 5, 2018 16:16:32 GMT -5
When you fill it do you ever overfill it?
Post by starclap92 on Mar 5, 2018 17:30:50 GMT -5
When you fill it do you ever overfill it? Sometimes i do
