Post by zummerp on Mar 10, 2018 17:03:03 GMT -5
So I’m sure I’m missing something, but how are you supposed to mount a license plate on the back of a Taotao? None of the holes appear to line up??
Post by tiny on Mar 10, 2018 19:27:35 GMT -5
Go to HomeDepot snd find some brackets and improvise. Had to on my ZX50 as the plate is longer then where the plate hole are on scooter.
Post by Danielle Belle on Mar 11, 2018 2:44:49 GMT -5
Mine didn't line up either. I just used zip ties.
Post by 90GTVert on Mar 11, 2018 7:50:33 GMT -5
MD motorcycle tag didn't line up on my 150 either. I had some 1" wide by 1/8" thick aluminum around so I made a bracket from that. Drilled holes to match the plate and the scoot. Bolted to the scoot. The bolt heads stuck out from the bracket so spacers would need to be used on the tag bolts. I installed my bolts sorta backwards so they worked like studs for the tag to go over. Instead of spacers, I just used nuts to secure the bolts for the tags and that spaced out the tag so it didn't hit the bolts to secure the bracket to the scoot.
Post by zummerp on Mar 11, 2018 11:27:46 GMT -5
Went super simple and just used zip ties
Rune 75
Post by Rune 75 on Mar 11, 2018 13:58:42 GMT -5
Perfect
yeska
Post by yeska on Mar 20, 2018 23:07:11 GMT -5
I place my to the bolt that are holding the black cover just remove the tail ligh cover little bit
Post by GrumpyUnk on Mar 21, 2018 12:05:32 GMT -5
I have this new invention. It's called an electric drill. I can use it along with drill bits of various sizes to make holes in wood, and sheet metal, such as license plates. If I make the holes to line up with the bracket holes, I can bolt the plate directly onto the bracket. In the above picture, the holes would likely poke through the "4" and the rightmost "C". Wonder if scrappydog would be upset? Most plates are aluminum, so would not rust, even in the salt states. tom
Post by 90GTVert on Mar 21, 2018 12:13:35 GMT -5
I have this new invention. It's called an electric drill. I had a MD state trooper tell me 20 years ago that he could give me some kind of big fine for altering a license plate, even for silly stuff that doesn't change the number or legibility. Wouldn't matter in the case of the Scrappy tag. Realistically, I don't think you'd have an issue unless you got a real ball-buster that happened to notice. I've seen so many tags on pickups in horrible condition from being in front of trailer hitches that stayed that way for years. I probably just met an officer that was in a bad mood or just finished reading a code book. Regardless, I try to fit state issued tags without modifying them.
Post by GrumpyUnk on Mar 21, 2018 20:34:15 GMT -5
I cannot argue with that as 'someone' will find a way to issue a citation if they so desire. Scrappydog? Not so much. tom
Post by jackrides on Mar 22, 2018 0:20:53 GMT -5
The mount. Oak is easier to work than metal. My Tao-tao took several operations and an excessive # of washers to make it fit right without violating the original mounts' integrity. As it turns out it would have been far easier if the damn branches had been removed first.
