Post by 'O'Verse on Mar 14, 2018 18:22:19 GMT -5
Post by oldgeek on Mar 14, 2018 18:31:23 GMT -5
Glad someone good made a home for that wayward motor! I could not tell you how many times I talked myself into and out of buying that thing.
Post by 'O'Verse on Mar 14, 2018 18:36:45 GMT -5
Post by 'O'Verse on Mar 14, 2018 18:40:34 GMT -5
Glad someone good made a home for that wayward motor! I could not tell you how many times I talked myself into and out of buying that thing. Yes sir. It will be loved like it was my own Baby! I’ve already told Spaz that he can have it back anytime he wants if need be. I thought I made people good deals. Spaz does it Jumbo style. Haha!
Post by tsimi on Mar 14, 2018 18:57:23 GMT -5
Well done overse! I am glad to see that the engine found a new home where it will be treated the way it should be and not end up getting messed up.
That pump is a very unique piece of work and we finally will be able to see what's what on that small scooter frame. I would not be surprised if it could keep up with your big beast.
Try to find a pre 2002 Aerox fork. That should fit.
Post by Jwhood on Mar 14, 2018 18:59:31 GMT -5
Man that thing is gonna fly,wish I could find a jog local but there never around
Post by PIG on Mar 14, 2018 19:39:42 GMT -5
Just throw the motor in it and send it! Stick with them super light jog wheels. Just get the proper speed rated tires. All the fastest scoots run 10 inch wheels.
Post by 'O'Verse on Mar 14, 2018 19:57:08 GMT -5
Well done overse! I am glad to see that the engine found a new home where it will be treated the way it should be and not end up getting messed up. That pump is a very unique piece of work and we finally will be able to see what's what on that small scooter frame. I would not be surprised if it could keep up with your big beast. Try to find a pre 2002 Aerox fork. That should fit. Yes sir I will. It might give the Testa Rossa a run for its money.... it'll be close. Both big bore Malossi products.
Post by 'O'Verse on Mar 14, 2018 19:59:22 GMT -5
Man that thing is gonna fly,wish I could find a jog local but there never around Yeah I got Lucky with this one. Scooterswapshop doesn't sell scooters just yet. So he sold this Jog to me as a friend. I guess I'll have to drop some dough his way in the future for more parts huh!
Post by 'O'Verse on Mar 14, 2018 20:02:20 GMT -5
Just throw the motor in it and send it! Stick with them super light jog wheels. Just get the proper speed rated tires. All the fastest scoots run 10 inch wheels. Speaking of wheels. The Aerox rims are a helluva lot lighter than are diamond pattern gyro's. Might just have to swap them bad boys out.
Post by Jwhood on Mar 14, 2018 20:04:55 GMT -5
Shoot get another one (jog) and make a twin then you'll have 3 company's( jack(testa Rossa) Larry (mrh 77) janet(twin 2fast)!!!!
Post by tsimi on Mar 14, 2018 20:12:52 GMT -5
Just throw the motor in it and send it! Stick with them super light jog wheels. Just get the proper speed rated tires. All the fastest scoots run 10 inch wheels. Speaking of wheels. The Aerox rims are a helluva lot lighter than are diamond pattern gyro's. Might just have to swap them bad boys out. didn't you modify the front wheel to fit the front caliper? It would be a shame if you need to grind on those nice Aerox wheels. If you are lucky it might fit as is though.
Post by 'O'Verse on Mar 14, 2018 21:05:03 GMT -5
Speaking of wheels. The Aerox rims are a helluva lot lighter than are diamond pattern gyro's. Might just have to swap them bad boys out. didn't you modify the front wheel to fit the front caliper? It would be a shame if you need to grind on those nice Aerox wheels. If you are lucky it might fit as is though. I did have the front rim machined down. A lot... I'll have to measure the thickness of both rims tomorrow to see if they'll just fit in another Jog tree as is. I won't be modifying any of Spaz's parts in case he needs them back. All bolt on. This build will mainly be for looks.
Post by tsimi on Mar 14, 2018 21:25:41 GMT -5
I see so it wasn't machined down to fit the caliper but to fit the fork.
Post by 'O'Verse on Mar 14, 2018 22:27:44 GMT -5
I see so it wasn't machined down to fit the caliper but to fit the fork. Se Senor!
