Post by KSR Moto on Mar 16, 2018 14:55:15 GMT -5
I am hearing some noise from variator side and to me it sounds like bad bearing, i have replaced clutch and bell but it can be heard again, what could it be variator?
Post by pinkscoot on Mar 16, 2018 17:50:02 GMT -5
Did you check your rollers to be sure they are okay? Maybe a video or audio file of the noise will help.
Post by KSR Moto on Mar 16, 2018 18:07:52 GMT -5
I didnt check the rollers but can they make any sound?, is sounds like a bad bearing and so far I am hearing it only at idle without wheel spinning, it sounds like quiet metalic ticking
Post by pinkscoot on Mar 16, 2018 19:03:33 GMT -5
They wear and can start to rattle.
Post by lilpinny on Mar 16, 2018 21:12:21 GMT -5
Post by KSR Moto on Mar 17, 2018 4:37:10 GMT -5
Is there any way to eliminate crankcase bearing?
Post by KSR Moto on Mar 17, 2018 8:19:00 GMT -5
Find out problem, it was variator 3 plastic parts which prevent metal to metal contact worn out
Post by jackrides on Mar 17, 2018 14:31:23 GMT -5
Stethoscopes are cool diagnostic tools. The closer it is to the problem the louder it is. Find a bad car pulley bearing in a heartbeat. But you can't listen to both at the same time.
Post by lilpinny on Mar 17, 2018 14:51:49 GMT -5
Find out problem, it was variator 3 plastic parts which prevent metal to metal contact worn out That's easy to fix ! Glad it wasn't anything more. Those variator guides are $5 or so.
Post by pinkscoot on Mar 17, 2018 19:19:18 GMT -5
Glad you found it. If it was a bearing the place to start checking is pull the CVT and see if there is any movement in the crank shaft. If none there pull the cooling shroud and check the flywheel for play. I had a bad bearing on a TGB and the flywheel had lots of play.
Post by shadowman on Mar 18, 2018 1:11:02 GMT -5
Well hopefully it didn’t trash your variator, because it will over time. When my scoot was my main ride, I always tried to have a spare set of the “v” guides on hand. It’s better than paying $30-40 for a new complete variator.
The more wear the 3 posts have that the guides ride on, the faster the “v” guides will wear out.
Post by KSR Moto on Mar 18, 2018 7:54:39 GMT -5
Well hopefully it didn’t trash your variator, because it will over time. When my scoot was my main ride, I always tried to have a spare set of the “v” guides on hand. It’s better than paying $30-40 for a new complete variator. The more wear the 3 posts have that the guides ride on, the faster the “v” guides will wear out. I agree that's why i have another entire engine just for parts got it very cheap😉
Post by GrumpyUnk on Mar 19, 2018 14:37:38 GMT -5
Instead of a stethoscope, a length of vacuum tubing works just as well in most cases. Gently hold one next to a functioning ear, and move the other end around the suspected noise making area. The tubing will block most ambient noises if held close enough, and will transmit noise without interference to the ear drum. It works pretty well, and is portable if you roll it up and stuff it in your pocket. tom
Post by KSR Moto on Mar 19, 2018 15:05:47 GMT -5
Instead of a stethoscope, a length of vacuum tubing works just as well in most cases. Gently hold one next to a functioning ear, and move the other end around the suspected noise making area. The tubing will block most ambient noises if held close enough, and will transmit noise without interference to the ear drum. It works pretty well, and is portable if you roll it up and stuff it in your pocket. tom This is gold,I like people like you who know how to use ordinary stuff in extraordinary way
Post by lilpinny on Mar 19, 2018 15:51:22 GMT -5
You can use a long screw driver like a stehiscope. Just touch it to the engine and put the handle side on your ear. Works, but not as well
